7. July 2021, 7:01
UPDATE: This article is OLD and describes the V3 Powertronic which is not available anymore. The V4 and V3 maps are INCOMPATIBLE.
V3 PT is orange, V4 PT has a black housing. The software is also different and incompatible.
Get R-tune software to modify maps here:
https://powertronicecu.com/downloads/
If you add your own map below please add a description to the link as for what the map does and for what driving conditions it is meant to be used.
This map: AFR about 12 to 1 in a 477 without modified camshaft but open air filter and exhaust:
https://drive.google.com/file/d/1wfzoHXljDhN918yHnTydEUrD9UtMjopj/view?usp=sharing
filename: PeakHP1.r2map
And this is the 462 map. Its a good starting point for a 477 optimized version.
https://drive.google.com/file/d/1PhEGnZhvEQ8SSAC2PMLjo39dX8PQpSTZ/view?usp=sharing
filename: BM7.5kminus 10.r2map
And this one produced 28 at the back wheel, 477cc with stock Cam and modded head.
A bit lean 3500 to 5500rpm:
https://drive.google.com/file/d/1ZMXIHP1jXZNBjG5WfcqGJMNgIq09ayV9/view?usp=sharing
Here is one we did for the 500cc Himalayan with a PT V3:
- what year bike
- what connection used to PT (e.g. o2 sensor yes or no)
- additional mods to the bike that change the performance (exhaust, airfilter, injectors, cams)
- if you did a dyno a chart would be nice
