Better front brake
Aha,now i understand where infaltion comes from. tt's the little kids in their mom's basement printing money illegally. Let me call my local police station and this will be sorted and all will be back to normal :LOL:
Enough, back to the topic....
So, I got the Scram 440 caliper. Will get it fit post Ramadan as my garage is closed till then.
But it seems a direct fit. The caliper is a 30-32 mm as compared to our stock 26mm.
As Sam already mentioned in another post, the braking on the scram 440 was better and I am hoping it will make things better on the 411 as well, combined with my radial brake levers.
did you change the disc as well?
Nope. The scram 440 also comes with a 300mm disc like the Himalayan. So I plan to first check the new caliper with the stock himalayan disc.
I do have a 310 mm disc with me that matches the disc mounts of Himalayan 411, but would need to create a mounting bracket for the caliper. So not planning to use that yet. Anyway it might be an overkill for the Himalayan.
the 300mm floating Brembo disc used in the 535 conti fits - I have used it on my BS3 Hima. fantastic results with the Brembo caliper going along with it
Yes I recall. That is the first post from Google search that lead me to the old forum, and introduced me to Himalayan Tools. 😁
Just a small update, measured the mounting bracket, it's not a match with himalayan. Slightly bigger gap between the two mounting holes and also bigger sized bolts.
Will be building an adaptor post Ramadan with my Mechanic.
Yeah, that sucks! I wonder if they do this on purpose or if they just don't care. I see this with so many different parts that almost fit but not quite. They should learn from BMW which had a policy (in the past) where you could exchange 90% or parts between models.
So, I did manage to Install the 440 unit on himalayan.
I got the 440 caliper bracket mounting holes filled up with welding.
Then redrilled them to match the hole and threading of the stock caliper bracket.
Did it's job well, now I can swap back to stock if I ever need and didn't have to spend much on a custom mounting bracket.
Braking is definitely much much better. Will see if I can grab a video this weekend.
I was doing a braking test. I don't have any distance measurement, but as I mentioned earlier, the braking is much much better. Check the small snip of a video from 110 kmph to 60 kmph without using any downshift.
  • HnVideoEditor_2025_05_04_012007962.mp4
    11.8 MB
