Lead Acid battery discharge / voltage map
I do have voltmeters on all of my bikes, even the bullets with amp-meter because it can give me an idea of the state of the battery before i engage the starter.
I was however under the impression that 12V is still like half full which is wrong, it only indicates about 30% load and considering you should never go below 10% not to endanger the longevity of the battery its very close to needing an outside recharge if it does not start the engine on first try.
Lithium batteries on my bikes are mostly higher than Lead Acid.
Helps with the skinny wires :cool:
