Hi all - I have now received my piston rings and am just beginning to do some pre- assembly work. I have two compression rings labelled N and N1 and the oil scraper set. Is there a prescribed order to fit them to the piston? The oil scraper set is obvious and I’m guessing N at the top and N1 in the middle. Also the preferred spacing for the gaps of the compression rings would be useful to save me guessing. My plan is to fit the piston to the barrel with one clip as per the video and then lower the pair onto the con rod. In the past I’ve fitted the piston to the con rod and then slid the barrel down easing the rings into the bore. The video makes sense avoiding the danger of damaging rings. Will this work with my N M W piston? Thanks in advance.
